Vaio Camera Capture Utility Version : 2.2.01.04100
Blencogo
For those who do not have a functioning Vaio Update 3, I see that the long awaitied VCCU Version : 2.2.01.04100 is available today on the AR31S download page at Vaio-Link Support
Haven't tried it yet and not sure if the Microsoft Hotfix KB931812 needs installing as well !!!
:slight_smile:
Edit: New link to VAIO Camera Capture Utility 2.2.1.04100 - Use SOACCU-01363004-UN.EXE
Also we have attached the Microsoft Hotfix KB931812 below..
58 REPLIES 58
Redsmurf
Thanks so much !!!! Finally it works!
Best regards
Alec006
please help!!!
with a clean comercial win vista install on a VGN-SZ5NX
what i need to make the webcam visible and working on my OS!
thanks
Blencogo
Hi Alec006 and welcome to Club Vaio.
You don't say what you have tried but with a clean installation of Vista you must: -
1. Install the camera driver
If you have saved your old C:\Drivers directory, just RUN:-
C:\Drivers\Camera\VGP-VCC?\DPInst32.exe
If not then download your C:\Drivers directory from here (Original Drivers Package): -
http://support.vaio.sony.co.uk/downloads/updates/updates.asp?site=voe_en_GB_cons&c=0&s=VGN-SZ&m=2660
Extract the files(right-click on the downloaded .ZIP and choose "Extract All")and run DPInst32.exe
2. Install the VAIO Camera Utility
Download the Original Utilities Package from here: -
Extract the files and run the Setup.exe in the 'Utils Installer VAIO Camera Utility' folder
3. Install the VAIO Camera Capture Utility
Setup.exe in the 'Utils Installer VAIO Camera Capture Utility' folder
The camera does not become visible in 'My Computer' with Vista - you just need to set it up with MSN or Skype and it will start automatically.
Good Luck.
:wink:
Alec006
(Where is the DPInst32.exe)????? only folders!!!
chipset
fingerprint
HDD Protection
Memory_Card
Modem
Network
Pointing
SFEP
SonyImgF
SonyPI
Video1
Video2
WirelessLAN
Blencogo
Well, that would explain a lot!!
The Camera Driver seems to be missing from the download.
Do you know which camera you have? I think probably the VGP-VCC6 but I'd only be guessing.
If it is the VGP-VCC6, you may have to download the drivers for the AR41_Series and run
AR4_Drivers\Drivers\Camera\VGP-VCC6\DPInst32.exe
I didn't bother to download your drivers and look at them. It would have taken too long with my slow internet connection! I assumed the camera driver would be there as on every other Vaio model. Apologies.
:slight_frown:
Alec006
i dont know what version of camera have
but this does not work for me
im desperate man please help me thank again
Gazza90
Have a FZ11 and the Camera Utilty is very annoying. Sometimes it works with MSN sometimes I have too go right back through the whole process...
Anyone with an easy fix... :slight_smile: Have a FZ11 and the Camera Utilty is very annoying. Sometimes it works with MSN sometimes I have too go right back through the whole process...
iansomm
Hi Blencogo,
I have the same problem with my SZ1/XP-C. I have followed your instructions and downloaded the orginal utilities and drivers,and camera utility but:
- how do I "run DPInst32.exe ?
- Where do I find the VAIO Camera Capture utility?
- and then, how do I Setup.exe in the 'Utils Installer VAIO Camera Capture Utility' folder?
thanks
Ian S
mickyg83
cheers mate this works and is easy to do . thanx again
Mano10000
I would download the Vaio Camera Capture Utility Update 2.2.01.04100 direct from the Vaio-Link server here: -
SOACCU-01363004-UN.exe
It doesn't matter where you download it to as long as you can find it to run the SOACCU-01363004-UN.EXE file. Something like c:\temp would do.
Just to recap generally on these camera problems!!!
If you have a Vaio newly released with Vista as the installed OS from January 2007 (VGN-FE41 VGN-AR31 VGN-SZ4 etc) then: -
1. Check you have the updated Vaio Camera Capture Utility 2.2.01.04100 installed.
2. Check you have the Microsoft Hotfix KB932812 installed.
3. Try reinstalling your camera driver at C:\Drivers\Camera\VGP-VCC?\ and double-click on DPInst32.EXE
If this does not work or you have a model which is new after Vista was released (VGN-FZ VGN-AR41 VGN-SZ5 etc) and your camera gives the message that it is "in use by another application", try reinstalling the Camera Driver as in 3. above. If no success then this is still an outstanding Vista problem between the camera driver writers and Vista's 'User Account Control'. The only known temporary solution to make your camera work is to disable UAC in Vista.
To disable User Account Control: -
Press the Windows key on the left of your keyboard and press R
Type in the command
MSCONFIG
and press OK -> Continue.
Open the Tab “Tools” and scroll down to ‘Disable UAC’ and click Launch. At the black screen, click OK and restart your Vaio.
I should point out that UAC is a security feature incorporated into Vista and disabling this may make your Vaio less secure. This has to be your choice but it will probably fix the camera!
:wink:
I have the AR31M. I have done everything you suggested in terms of a fix. I still get the same error message of
"NO INPUT
"VIAO CAMERA CAPTURE UTILITY
An attempt to initialize the camera failed.
Please check if another software is using the camera"
First off, that's not even English!
Second, I agree with the post above that it is beyond belief Sony can send out laptops with integrated cameras that don't work. I would never had bought it had I realized.
Third, I followed your instructions to disable user account control. When I typed OK at the black screen I got an error message saying you can't type OK here, so I just closed the black screen. Hopefully that was what you were intending to say?
If that's the case, I've disabled user account control and I still get the same error message when I try to use the camera...
Has anyone got any more suggestions?
Thanks
