VGN-SR4 "Base Device Driver@
bluey2
I recently upgraded to Windows 7. All is well apart from one device driver: Base System Device. I think it is the memory card duo driver. Does anyone have the driver?
Thanks
1 REPLY 1
rich912
Contributor
Hi bluey2 and welcome.
You are correct in your assumption that the 'Base System Device' is most likely the Card Reader.
As there is no available Card Reader driver listed for your model under the Win 7 upgrade drivers, have you tried the original Vista Card Reader driver?
Go n-éirí an bóthar leat
