I have a VGN A617S and have just done a full system repair which has taken things back to default settings. Before the repair, when I clicked on the My Club Vaio icon, a black screen used to appear and then a blue "syncronisation" circle would build and then take me to a list of programs etc which are available on the computer.
After the repair, when I clicked on the icon, the black screen appeared and a blue progrees line swept across the screen and it opened up.
Now however, when I click on the icon, the black screen appears but it just hangs and does nothing.
In case it makes any difference, I have downloaded some Sony upgrades.
Can anyone help me please
Hi FJM,
are you referring to the My Club VAIO as seen below.?
yes that's exactly it
How do I get to the information behind the screen - I used to access the User manual via this screen
Is there another way to get to this Document ?
Hi FJM,
you should be able to access the User manual by clickon My Computer, followed by C drive.
In the C drive click on Documentation folder & Documentation folder again, followed by the language folder of your choice.
If the User manual is located as I suggest above, to make it easier to access next time you could create a shortcut on your desktop.
I have included a quick guide on the process should you wish to create a shortcut..
Right-click on the User Guide.PDF files and point to Send to and then Desktop (Create Shortcut)..
