I have an Xperia X10a through AT&T. I'm having trouble downloading backup-and-restore. Apparently my phone is set to receive Android Market apps only. Anyone have a solution?
the second option if you want to get gingerbread (android 2.3.3) in the next few days/weeks
debrand your phone
this is flashtool incase you want to try this to fix your phone (it will fix it)
download FlashTool and the firmware that you need from
http://forum.xda-developers.com/showthread.php?t=920746
Install it and you will see 5 folders
the reason it doesn't work its bc AT&T has blocked the phone to sideload apps, the only way you can do is
live with it and use this apps instead
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Log
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
Contacts
just to play it safe sync your contacts w/ google if you haven't already
debrand your phone
This is an step by step guide
5.
a. Unplug your USB cable from the PCb. Power off your phone and plug the USB into the phone
c. Press back button and keep your finger on button
d. Plug USB cable into your PC whilst holding down the back button on your phone
e. A green LED will appear
f. The process will automatically detect your phone and start flashing
g. When "Found at USB/........" appear on flash tool you may release"back button", sit down, relaxand wait.
Hope this is helpful to you
6. IF the "Start Flashing" message appear everything`s ok if not...repeat. Sitdown and relax (again )
7. When last message appear unplug/plug USB cable
Regards,
Ricardo Rendeiro
Thank you uliwooly! That's exactly what I was looking for. Starting to rethink the whole AT&T thing. So many issues!
I don't know anything about Gingerbread, but I'm definitely interested in updating my phone to the fullest! Think it will cause problems with my AT&T service or with my Google sync?
it will not cause any issues neither AT&T nor google.
indeed they do
