Xperia X10a update problems
I have an Xperia X10a through AT&T. I'm having trouble downloading backup-and-restore. Apparently my phone is set to receive Android Market apps only. Anyone have a solution?
Uliwooly
the second option if you want to get gingerbread (android 2.3.3) in the next few days/weeks
debrand your phone
this is flashtool incase you want to try this to fix your phone (it will fix it)
download FlashTool and the firmware that you need from
http://forum.xda-developers.com/showthread.php?t=920746
Install it and you will see  5 folders
                                   Custom
                                   Drivers
                                   Firmwares
                                   Loaders
                                   X10Flasher_lib
take the firmware to the  "Firmwares" folder
click on X10FlashTool (Application)
click on Falsh
Press Ok
it will ask you to connect your phone on Flashmode (turn off your phone, press the back button, then connect the USB) press OK
Click Flash
8 REPLIES 8
Uliwooly
the reason it doesn't work its bc AT&T has blocked the phone to sideload apps, the only way you can do is
live with it and use this apps instead
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Uliwooly
Call Log
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
Contacts
just to play it safe sync your contacts w/ google if you haven't already
open your phonebook
press MENU button -> tap on Send Contacts -> select all -> send it to your email
on your computer
-> download the file -> go to your gmail -> click on contacts -> click on more actions -> on the drop down menu click on "import" -> choose the file -> and click import
Uliwooly
debrand your phone
                                   Custom
                                   Drivers
                                   Firmwares
                                   Loaders
                                   X10Flasher_lib
click on Falsh
Press Ok
Click Flash
Uliwooly
This is an step by step guide
I WILL NOT BE RESPONSIBLE IF ANYTHING GOES WRONG!!!
OPTION 1 - Install *.ftf files
1. Install Flashtool
2. Copy the *.ftf files that you `ve downloaded earlier to firmwares folder from Flashtool.
3. Click "Flash" button from flashtool and select the *.ftf file firmware and click "OK"
4. Relax and wait a while. When the proccess is completed you will get a popup message (don`t click on that!!!)
5.a. Unplug your USB cable from the PC
b. Power off your phone and plug the USB into the phone
c
. Press back button and
keep your finger on button
d
Plug USB cable into your PC whilst holding down the back button on your phone
e
. A
green LED will appear
f
. The process will automatically detect your phone and start flashing
g. When "Found at USB/........" appear on flash tool you may release"back button", sit down, relaxand wait.
Hope this is helpful to you
6. IF the "Start Flashing" message appear everything`s ok if not...repeat. Sitdown and relax (again )
7. When last message appear unplug/plug USB cable
8. DONNE
Regards,
Ricardo Rendeiro
Thank you uliwooly! That's exactly what I was looking for. Starting to rethink the whole AT&T thing. So many issues!
I don't know anything about Gingerbread, but I'm definitely interested in updating my phone to the fullest! Think it will cause problems with my AT&T service or with my Google sync?
Uliwooly
it will not cause any issues neither AT&T nor google.
Uliwooly
indeed they do
