I tried switching off the phone to save the battery since it drains up each night.
But I was shocked to find that my alarm did not work.
Am I missing something, Is there any setting where I could make it wake up to ring the alarm ?
I know that it has nothing to do with Android since I had an Android device that could auto sleep and wake up at specific times.
If it is a hardware level problem with this phone, It would be really disappointing
Yes. When I keep Wifi Switched Off, the battery lasts much longer.
For Anyone reading this later:
1) To find out if it's possible to use the Alarm when the mobile is powered off:
The Answer is NO.
2) If the battery is running out too fast, then make sure you turn off Wifi when it's not in use.
Just maintaining a wifi connection uses a lot of battery even if no other App is actually transferring data.
Thanks for all your help uliwooly-wooly.
anytime, don't forget to backup and sync everything on your phone, just in case your phone start acting up
this is how
Use one of these links to download the Backup & Restore app
http://forum.xda-developers.com/showthread.php?t=1193802
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
http://www.mediafire.com/?1n07llajeaoo03y
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
just to play it safe sync your contacts w/ google if you haven't already
open your phonebook
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
