Hi all can anyone tell me if there is a screen protector allready fitted to the phone out of the box. As it looks like there is on an it.
Cheers friend spoke to voda about this and they were no help.
Are they easy to replace
You need to replace it? I had another one (came in the box) over it, double protection .... Actually, I was not aware till I looked closer. 😛
I have always used my phone with the factory fit one and a purchased one over the top. I have had to replace the shop one only recently having had the phone since last June.
The factory one is well and truly stuck down but will come off if you are very careful and persistent. I would leave it in place unless the screen is badly marked.
Hi all, hope you can help me. I've got my X10 for a year and since the beginning were told that it comes with factory fitted screen protector and the one in the box is spare. Recently found some scratches on the factory fitted one and would like to replace it with the one in the box. Went to a Sony Ericsson outlet to confirm and ask them to change for me, they said there are no factory fitted screen protector at all. The one on the screen is not a screen protector though he can pull out a bit of the corner. I'm now lost. Is it a screen protector to start with? Can I have it replaced or have to live with the scratches??
HELP!!
look closely if you see a film on top of the screen then yes it has one, it is quite hard to remove though
