Hi!
My Xperia arc don`t want to connect to 3G\GPRS network. I tried everything I can, except downgrade. Can anybody help me with my problem? Thank you
go to settings -> sony ericsson -> internet settings -> accept
settings -> wireless & network -> mobile networks -> access point names -> MENU -> add new -> enter the data -> menu -> save
also check if there's any issue with your SIM card and/or coverage
uliwooly, thank you for your reply, everyhing starts working. But funny... I did it earlier, couple hours ago, and this attempts was unsuccessful. Thank you once again.
No problem, I'm glad its working now
After rebooting mobile problem appears again
Can it be a problem with SIM card or my operator? I tried another SIM with another operator and it`s works perfectly, without any manipulations with internet settings. Sorry for my english
Another "Factory data reset" solved the problem, for now
diemas i'm having exactly the same problem. check my discussion. I also did the factory reset, and it started working... but a day after it's not working again. the APNs are auto-deleted somehow =(
edit: don't know if this helps, but i'm in portugal using TMN operator. funny that you've tried another sim card and it started working... hmmmmmmmmm
Hi!
I`m from Estonia, using Tele 2 operator. Before factory reset I tried automatic settings from Tele 2, and mobile refused to use them with message "settings cannot be used with your SIM", or something like that. After that I tried manual settings. I took another Xperia with Tele 2 operator (by the way Xperia Neo also upgraded to 4.0 firmware by me with my PC), opened APN and write down same settings, tap Save and nothing happened. I mean APN wasn`t saved.
Diemas i tried a different sim card (from another operator) and it worked fine ............... =\ so i guess it's a problem with the update and some sim card.
i also had o disable PIN security. ... i'm still having the problem since my current card still doesn't save APNs. guess i'll have to buy a new sim.
cheers
