For the past week I haven't been able to connect to any wifi networks. It always says "out of range". This has only been happening for the past week.
Try turning the Power save off, in the Advanced wifi settings.Otherwise, and if you haven't changed any other settings, try running the update service on the phone and see if that solves the problem.
No worries.
