I charged the phone.
At one point, switch off the power, time passes ...
Later, wanted to see the time - does not respond to buttons.
I reconnect the battery, try to restart the phone.
It shows a red LED and nothing else.
seus does not update the phone.
what are the solutions to the problem?
upd
after my actions
now it shows SE Logo, but xrecovery is not loading
may try to load the firmware into the phone with 3rd party flasher?
Not sure if this will work. Since phone is able to connect to PC/Laptop, why not do a Software repair?
That's what I am referring to!
seus tell me
your phone have last firmware. and don't want to reflash it
I now fall under the table with laughter
Why?
we talk on the official forum for unofficial flasher
Hmmmm .... did I? I mentioned Software repair!
Oh. Sorry. I did not understand at first time.
But i try it now. Successful begin of process now
but after reflash i have That's the same as at the beginning of my question
Well. I understand. I need go to service-center
This is hardware problem with charge sensor,...
Great!
Any which way .... as long as it works .... then that is the best way!
Glad .... keep us updated.
