I charged the phone.
At one point, switch off the power, time passes ...
Later, wanted to see the time - does not respond to buttons.
I reconnect the battery, try to restart the phone.
It shows a red LED and nothing else.
seus does not update the phone.
what are the solutions to the problem?
upd
after my actions
now it shows SE Logo, but xrecovery is not loading
Oh .... phone still dead?
Ok, at least you found out the problem ....
after second reflash:
- LED blink with RED
- with pressed 'back' i connect the phone - GUI loaded
and I was not right, the problem not in the charge sensor
/without cable phone shows 'less 3% battery'"
but with other battery - shows right charge level
Probably an intermittent problem with the phone usb connector. Guess you have to send it in for repair.
Just send it in to SE Service Center for tech to confirm the problem.
thanks for help
problem was banal. it just got worse battery. that is strange. I bought the phone on February 14.
Welcome, hope you will get your phone repaired
