Problem with Facebook after update to Android 4.4
MatGenau
After updating my Xperia E1 on Android 4.4.2 (Kitkat) my Facebook App was automatically uninstalled. If I want to install the app from Google Play Store I get the Message "Incompatible Version" and the installation is aborted. I shut down my mobile, removed sim-card and battery put both in again and than started the phone again but that changed nothing. A repair over PC Companion failured also due to no available software. Can you help me? thanks a lot:smileysmileythumbsup:
44 REPLIES 44
SawsanZizi
can we as Xpira users claim our money back due to software update falier to operate normally and non_professional responces from Sony support?
SawsanZizi
*failure
Rickard
Master
If you want to return the phone i recommend that you contact your local support team to see if that's possible.
But if you repair/reinstall the phones firmware using a computer and PC Companion or Bridge for Mac this should solve the issue.
sanban
I cannot download facebook. After complete download it is showing "incompitable update". Pls suggest how can i download it.
johnghill
I have had same problem,why was I asked to update my xperia and now I cant get facebook the only app I almost use,I have tried what was suggested and still nof acebook,need an answer now ?????
johnghill
tried and failed,what now?
Rickard
Master
@johnghill
Sorry to hear that.
Can you please clarify if it was the repair of the phones software that didn't work or if the software repair worked but didn't solve the issue with Facebook?
XperiaDualE1
Give a Reboot on your E1! It will comeback with 4.4 and the Facebook operating normally!
Logikal
Factory reset worked but make sure you back up everything first. If you have an SD card, just throw everything to that as it only deletes internal storage. I took the SD card out before the reset to be ultra safe anyway tho Slightly_smiling_Face
Uyi46
SAME PROBLEM ABOUT FACEBOOK WITH MY XPERIA E 1 AFTER UPDATE TO 4.4 KITKAT. What should i do? When download at google playstore it always appear "incompatible update". Help me . Facebook is very important to me . Thank you for helping .
