lockscreen bug
Vladibeer
lockscreen bug
I recently bought two E4s for me and my wife. All is fine but there is this very annoying visual bug on the lockscreen. Almost every time I turn on the phone, the clock widget appears duplicated on the bottom of the screen where the camera and operator icons are. It happens for half a second and disadisappears. Everything is updated and with stock firmware and software. This happens on both phones. Id appreciate any help getting rid of that problem.
24 REPLIES 24
Uliwooly
@Vladibeer
You will need a third party lock screen app that might allow you to do this as Lollipop doesn't have this feature.
saeed2015
Why cant?
Go to settings.. Personalization... change wallpaper.. Home and lockscreen... Live wallpapee
And set it
Uliwooly
@saeed2015
I stand corrected, I only locked under "Lock screen" not Home & lock screen
Settings > personalization > wallpaper > Home & lock screen
Uliwooly
@saeed2015 @Vladibeer
The lockscreen and home screen must have the same live wallpaper, if you switch the home wallpaper the lock screen will change the wallpaper to a generic Sony wallpaper.
Vladibeer
Have you even tested e4? No such option available..
