lockscreen bug
Vladibeer
lockscreen bug
I recently bought two E4s for me and my wife. All is fine but there is this very annoying visual bug on the lockscreen. Almost every time I turn on the phone, the clock widget appears duplicated on the bottom of the screen where the camera and operator icons are. It happens for half a second and disadisappears. Everything is updated and with stock firmware and software. This happens on both phones. Id appreciate any help getting rid of that problem.
24 REPLIES 24
Vladibeer
OK, here it is. You can see the bug on the bottom of the screen the second time I turn on the phone. https://youtu.be/o6cDIT3V-9M
profile.country.RO.title
_alexdon_
I think @Hampus might want to take a look.
alexdon
Vladibeer
Now i notice its not just the clock widget but also the status bar - the whole upper part of the screen loads first at the bottom for a split second. Btw i tried changing the lock from swipe to pattern to none, the bug is still there.
sammygoforit
Maybe this will help
Vladibeer
Anyone?
Hampus
Champion
Could you please send me your details in a PM, and I will forward this.
Make a relevant topic and include the following.
Name:
Phone nr:
E-mail:
Country:
Operator:
Product(s):
IMEI nr:
Build number:
Vladibeer
Thanks, just sent you a message
Hampus
Champion
Hi again,
We have tried to replicate this but it cannot be replicated. Our developers say that it may be caused by very specific settings that you have in your phone that caused heavy processor load. It is possible that processor is not re-activated fast enough in very specific conditions to show the clock on the correct position immediately. The developers are continuously improving the performance of the software, so if and when it's an update available please update the phone
Vladibeer
Thank you for your efforts. This is not setting related as it happens even after factory reset. I thought it could be stamina mode that interferes but with disabled stamina the bug is still there. Any idea when the update is rolling out? Will E4 get Lollipop as well as high end devices?
Vladibeer
Dont mean to hijack the topic, but is there a way to set live wallpapers on lockscreen? I like both lockscreen and home to look the same.
