Xperia C4 Dual - Rebooting when connected to charger
236
I am facing a very weird issue with C4 dual. Whenever, I am connecting my phone to charger for charging, the boot boots, Xperia logo apprears and phone shutt off. Again, the same thing gets repeated.
I have tried using different chargers but the problem still persists. Its very annoying and irriating.
Could any one help me out what exactly is the matter? Its the hardware problem or something else?? I am not able to use my phone since it is not getting charged?
Regards
Hardik
39 REPLIES 39
Hampus
Champion
That sounds strange. When you say different chargers, do you mean both cable and adapter? Have you tried different wall sockets?
profile.country.RO.title
_alexdon_
Is it the original charger?
alexdon
amit_rocking87
By any chance have u ever tried to play with charging port of mobile like u pressed charging port hardly or some other make charging pin u inserted in your mobile?
Also just for my info trust u have not any voltage fluctuations issue?
236
Hi Hampus,
Yes, I have used to OEM's cable+charger, also tried charger+cable cord of other company as well (samsung and htc).
I have used usb charging from PC as well as wall socket method but he problem persists. After continuoulsy trying connecting and disconnecting chord from mobile, sometimes phone detects and charges. But the moment, I disturb the positioning, it again goes back to same old mode (switch off and rebooting).
I backed up all my data yesterday and did factory reset thinking it might be software issue. Still not resolved.
Any suggestion would be highly appreciated.
Regards
Hardi
236
Hi Amit,
Not i haven't pressed the mobile usb hardly. No votlage fluctuation as far as I can recall.
Thanks
Regards
236
Yes, it is the original charger
Regards
Hardi
amit_rocking87
From when this problem started?
I guess there is port issue and nees to replace.
Please contact your local SC.
236
Hi Amit,
It started 5 days ago... last 3 months it was fine....
amit_rocking87
Thanks good to know.
I suspect port malfunction. Pls check with local Sony SC
