XZ restarts continuously
Kredenn
What to do if my brand new XZ keeps restarting by it self every 5-10 minutes?
19 REPLIES 19
Kredenn
Now it's rebooting again once and a while, seems like it hasn't been fixed properly.
Didrik
Enthusiast
Hi again @Kredenn,
Sorry to hear that you are still having troubles with your phone. A good next step is, as @Viridis suggested, trying to get a new SIM-card from your service provider. That way we can rule out a faulty SIM-card being the cause of this.
Could you also try rebooting your phone to safe mode? Are you then still experiencing this?
SKenduser1
I’m also having this issue…
It happened after it began updating apps overnight (Play Store)
The next morning noticed it needed pin code to start again. Then it went in to boot loop… 😕
After resetting the phone with PC companion it randomly restarts after X minutes!
Now after reading this topic I’ve ordered a new SIM from carrier.
Really hope it’s faulty SIM causing this…??? 😕
Didrik
Enthusiast
Hi @SKenduser1,
First of all I want to apologize for a late reply, I've been out of office for a while.
I'm sorry to hear you are experiencing this.
If you have tried what's previously been suggested in this thread I would recommend that you wait until you have received your new SIM-card. A defect or faulty SIM-card can cause the phone to reboot since if your handset loses connection to the SIM.
Have you now received your new SIM? If so, please let me know if there was any change when you started using the new SIM-card. Slightly_smiling_Face
SKenduser1
Dear Didrik,
Thanks for your reply.
I've already received the new sim.
But the problem still exsist...
The screen would freeze and few seconds later reboots by itself.
Also noticed it would restart itself even without using or touching the phone!
Things I've already tried:
- Factory reset on device itself and using software repair with Xperia Companion, problem still remains after trying out both methods...
- Booting in safe mode, phone still reboots after X minutes...
- I've also tried using the phone without SIM or microSD card insert, but it will still reboot after X minutes... (I'm sure the SIM and microSD is not faulty, as its functioning fine in my Xperia Z5)
In the mean time I’ve received update to the latest software (39.0.A.1.250), but sadly it didn't help 😕
I've contacted Sony Belgium but they couldn't help me because the phone is bought in Hong Kong. Slightly_frowning_Face
It seems only Sony Hong Kong can help me... so I've sent it there now.
Very disappointed at Sony Belgium services! Angry_Face
Didrik
Enthusiast
I'm sorry to hear that @SKenduser1. Slightly_frowning_Face
The way that you describe what you are experiencing makes it sound related to hardware rather than software. My guess is that you made the right decision in having your phone sent for repairs. I would, in this case, recommend that you wait until the service centre has examined your phone.
As far as I know the warranty isn't global, which might be the reason that you had to send your phone to the market it was purchased from. I would suggest that you contact your Local support in order to get confirmation on this as they will have more information on this subject.
I really hope this works out for you smoothly Slightly_smiling_Face
SKenduser1
Hi Didrik
I hope so too... Face_with_rolling_Eyes
I'll try to update once I have more news from Sony HK on this matter...
Best regards,
SK
Didrik
Enthusiast
That sounds like a plan @SKenduser1. Let me know how it goes! Slightly_smiling_Face
SKenduser1
@Didrik Thanks for your posts...
I've received update on the repair...
It seems the software got corrupted unknown reason.
They needed to perform a deep reset that only at Sony service center can do.
Regular reset on device and using Xperia companion does only like 80% clean install?
The engineer tested it and was back normal he said… (let’s hope so…) Nerd_Face
I’ve also got noted the device did not pass the pressure test, because one of the plastic edges is not closing properly/minor bended…? Thinking_Face
To get this replaced I need to pay like 55€ and wait 3 weeks for replacement parts from Japan to arrive.
Guarantee does not cover this because the phone is already being used.
I really don’t understand how this could happen, due to the fact I didn’t even have a chance to use this phone properly in the first place and it’s still new…
Grrrr… not happy at all at Sony!!! Angry_Face
The Phone is going to be sent back to me now with just the software repair.
The waterproof thing I don’t really need anyway, so not going to get that fixed.
Let's see how it goes... when receiving back the phone.
RickyNg
Hi there, i also encountered this problem. My sony XZ also keep rebooting. When i playing game or scrolling my facebook, out of sudden, it restart like a loop =,=
