Hello dears. There is an issue with my XZ2 Premium. While I can download and install themes from the Play Store all right, I have a problem when i click on "Get more Themes" inside the Themes collection of the phone. I just get the message "Themes keeps stopping". Anyone can figure out what's causing this? This problem persists after factory reset also.
Additionally, I wanna know which is the best website for XZ2 Premium themes? (Apart from Play Store that is).
And finally, there is supposed to a way that themes change not only the wallpaper, icons and lockscreen, but also the entire interface including system menus, fonts and everything else. Please share if you know the tricks.
You can try some theme changing apps too, they're easily found in the Play store, you won't have to run through webpages and all that.
