Opening SIM-tray reboot the phone
kloana
when i open my SIM-Tray on my Android 7.0 Nougat, my phone do a automatic reboot. WHY? There is no change in the SIM-card. Just openeing the tray, initiate the reboot??!?!?
Do you see this behavour on your phones too?
Thanks in advance,
regards
Herbert
6 REPLIES 6
100rabh
Yeah.. It's a special Sony feature.. They don't want to fix this... i guess this is happening since 4-5 years or more
kloana
Ah ok. It's not a BUG it's a feature.
Thanks for this information,...
So in this case i don't have to ask SONY to correct this,...
regards
Herbert
profile.country.PH.title
MarlonUk1
@kloana: yes, its supposed to work that way, I don't the reason behind this but, I think its like the "safety" mechanism to avoid coruption of the sd card...
kloana
Maybe, but do you switch off your pc before you connect your SD-card? 😉
MarlonUk1
yes, back when I was using windows 95. Winking_Face
Lord_viridis
It's supposed to do this and has since the first Z, maybe longer.
It is to protect the SIM card from corruption as the pins to the SIM are not linear so a longer pad could end up with 2 contacts on it and could short the SIM reader.
The obvious protection is to just reset the whole system when it detects the SIM slot is open.
