when i open my SIM-Tray on my Android 7.0 Nougat, my phone do a automatic reboot. WHY? There is no change in the SIM-card. Just openeing the tray, initiate the reboot??!?!?
Do you see this behavour on your phones too?
Thanks in advance,
regards
Herbert
Ah ok. It's not a BUG it's a feature.
Thanks for this information,...
So in this case i don't have to ask SONY to correct this,...
regards
Herbert
@kloana: yes, its supposed to work that way, I don't the reason behind this but, I think its like the "safety" mechanism to avoid coruption of the sd card...
Maybe, but do you switch off your pc before you connect your SD-card? 😉
yes, back when I was using windows 95.
