SD Card automatically ejecting after update
Kedarmane
Today 22 Sep, my xperia XA got updated, after that my sd card automatically gets ejected. My new build number is 33.2.B.3.74.
Tags (1)
53 REPLIES 53
Jenlee916
I have same problem with my sony xperia xa. It happened after I updated it. Sony, do you have any solution to this problem.... Its so frustrating, I feel like I want to sell this phone....
Adityalk
Please reset the phone by removing the SD card and then insert the SD card, the error will not show I guess
babyju5t
it not show until you move app to sd card again
Jenlee916
I already did it, removed the sdcard and insert it again, but the phone did not detect the sdcard, so I restart the phone, it detect the sdcard but after a second or minute its says "sdcard ejecting do not removed"
babyju5t
That's what I'm facing too. I'm now using my phone without sd card, the notification doesn't appear again. The only solution to continue using sd card is waiting for updates from sony, I guess.
Jenlee916
They have to advice their user if that so, thats why they their customer care to answer queries. BUT they are not replying.. . Slightly_frowning_Face
nikola2004mkd1
Had the same problem with two M2 phones. Two cards that were used in previous phones died after one week, after showing the same symptoms. Another 2 died after one month. However the next one that I bought is good even after two years, and one of them is now in my XA.
JimgimJim
Do you guys have any update on this? I just cant go with the master reset, this is just unacceptable
Lyliang777
Move my app back from sd card to internal storage help me on this problem. Just use the SD Card to save mp3, photo, video and other file.
sanket_rane
adding to this update issue NFS NO LIMITS Game was just working totally smoothly before this update now its loading slow and its lagging what is wrong with developers of sony why can't test the update before it goes out too many issue with update. i just hoping bug fix will be soon for sd card issue i still can't transfer application to sd card
