Hi all,
on my MacBook Pro with OS Catalina the BT is not finding the WF-1000XM3.
Anyone have a hint to make it pair?
I have also a pair WH-1000XM3 which works just fine.
Warmest regards
Heureka!
After the upgrade and the reset they worked as expected!
Thanks!
Hi lbennrup,
Happy to know it's working !
Cheers,
The_Black_Rose
Doesn't work
I followed all the suggestions. I rebooted my macbook (running catalina). I reset the headphones. I upgraded the software. I made sure all other bluetooth is turned off - these sony headphones are not recognized by my macbook pro's bluetooth
