Trouble Charging my WH-1000XM4
Rogmar75
Hi - I am struggling to charge my WH-1000XM4 Headphones
When i plug them in nothing happens
i am using the supplied charger cable and have tried multiple charging plugs
When i plug into the USB on my laptop - the laptop reads that something new is connected but doesn't charge
Any advice would be appreciated
Thanks
3 REPLIES 3
HannahEd01
Hey Rogmar75, you might have gotten a faulty one. Is this out of the box? If yes try the retailer to exchanged.
Rogmar75
Thank you - Yes out of the box (which i still have) - bought it at Currys in Feb
HannahEd01
Hey Rogmar75, if it was like this out of the box that should be addressed with the retailer.
