Several headphones with the same name (WH-1000XM3) in the same airplane
profile.country.NO.title
PerErling
How can you change the name on your headphone so it will be easier to find with bluetooth?
PerErling
Hello Nic.
It was a big problem the first time I had to pair the headphones on board a plane. Suddenly there were five available WH-1000XM3s on board. Now I have solved the problem: If you click "settings" behind the WH-1000XM3 in "paired devices", a new option will appear, "Rename". My headphone has now been renamed and it works great.
3 REPLIES 3
IamNic
Hello @PerErling,
no, you can't change the name of the headphones - I also don't see why that would be an issue.
Once you are paired to your headphones, your devices will automatically connect to your set of headphones and yours only.
- Nic
PerErling
Hello Nic.
IamNic
Hello @PerErling,
yes, you can rename them on your phone, but the name won't become the devices new name. If you search for them via another device they still have the default name.
- Nic
