Bluetooth functionality not working on my sony vaio.
JamesTopman
All of a sudden i cant pair my phone with my laptop anymore and the option to send files from my laptop with bluetooth has dissapeared. Can i have help with this?
rich912
Contributor
This is an extract from your manual. It seems that Vaio Smart Network is not used with Win 8. It would be worth checking that the device has not been turned off.
Stopping BLUETOOTH(R) Communications
You can stop BLUETOOTH communications by following these steps.
1. Open the charms [Details] and select the Settings charm.
2. Select Change PC settings in the lower right corner.
3. Select Wireless in the left pane of the PC settings screen.
4. Change the Bluetooth setting under Wireless devices to Off.
Hint
• When Airplane mode is Off, the WIRELESS indicator light on your VAIO computer stays on.
Go n-éirí an bóthar leat
14 REPLIES 14
rich912
Contributor
Hi JamesTopman,
Have you checked that Bluetooth is turned on in Vaio Smart Network? Just occasionally an update can turn it off.
Otherwise try reinstalling the driver.
Rich
JamesTopman
where is the vaio smart network? i dont seem to have it installed.
rich912
Contributor
Which Vaio model do you have?
Assuming that you have the original installed OS and that it is not ancient you should find Vaio Smart Network in Vaio Control Center > Network Connections or look for the icon in the system tray...undefined
Rich
JamesTopman
I have an SVS13 model. When i go to control center and then network, i see this:
undefined
... now what.
rich912
Contributor
Vaio Control Center is not displaying as it should. The items listed in the left pane should be expandable and you are missing ‘System Information’ which should be top of the list. Which operating system are you running? If it is Windows 8 perhaps another member could confirm that the items should be expandable as I don’t have a Win 8 Vaio.
With Win 7 Vaio Smart Network is located at C:\Program Files\Sony\Vaio Smart Network and can be run from VSNClient.exe. I’m afraid I have no idea where it is located with Win 8 or even whether it exists.
Rich
JamesTopman
Yeah i am running iwndows 8, and this seems to be the only "vaio control center" on my computer.
There also isnt any "vaio smart network" app on my computer.
rich912
Contributor
As the OS is Win 8 I’m not sure that I am going to be of much help to you but I suggest that you try reinstalling the following:
Sony Notebook Utilities.
http://www.sony.co.uk/support/en/content/cnt-dwnl/prd-comp/sony_notebook_utilities_8355/SVS1313C5E
System Settings Program:
http://www.sony.co.uk/support/en/content/cnt-dwnl/prd-comp/EP0000298538_8632/SVS1313C5E
Bluetooth Driver:
http://www.sony.co.uk/support/en/content/cnt-dwnl/prd-comp/EP0000296997_8601/SVS1313C5E
Restart after each installation.
Rich
rich912
Contributor
Hint
JamesTopman
Ohh bluetooth was turned off for some reason. Just switched it back on and now it works.
Thank you :slight_smile:
