Will updating apps through android market reduce my phone's internal memory?
hey guys, i noticed that i need to download a few megabytes of file each time there are updates for those apps i downloaded. and i am curious whether those updates will decrease my internal memory or not... anyone have any idea about this issue? 😃
Uliwooly
by updating an app, you pretty much replace the old app with the newer version, unless the apk its heavier/bigger it should'nt decrease your internal memory.
7 REPLIES 7
Uliwooly
don't worry about that, you can move your apps to your SD card
settings -> applications -> storage use -> tap on "On SD card" select all of them so you can move them to the SD card
Uliwooly
Hey uliwooly=) i am talking bout those apps that cannot be moved to SD card. If i upgrade those apps... will my internal memory decrease? gingerbreak for 2.3.3 is not out yet that is why i did not root my arc=)
Uliwooly
Uliwooly
it seems that some people managed to root 2.3.3 on LT15i, it hasn't work out for me just yet
http://forum.xda-developers.com/showthread.php?t=1115542
thanks uliwooly. a great help as usual=) LOL. yea. i read that article before. Don't really trust it though. Hope that gingerbreak for 2.3.3 will be out soon!
Uliwooly
I know, I really need to root my Arc but we'll see if someone at XDA find a way around it
