hey guys, i noticed that i need to download a few megabytes of file each time there are updates for those apps i downloaded. and i am curious whether those updates will decrease my internal memory or not... anyone have any idea about this issue? 😃
by updating an app, you pretty much replace the old app with the newer version, unless the apk its heavier/bigger it should'nt decrease your internal memory.
don't worry about that, you can move your apps to your SD card
settings -> applications -> storage use -> tap on "On SD card" select all of them so you can move them to the SD card
or you can use this app to move apps to your SD card
https://market.android.com/details?id=com.a0soft.gphone.app2sd&feature=more_from_developer
Hey uliwooly=) i am talking bout those apps that cannot be moved to SD card. If i upgrade those apps... will my internal memory decrease? gingerbreak for 2.3.3 is not out yet that is why i did not root my arc=)
it seems that some people managed to root 2.3.3 on LT15i, it hasn't work out for me just yet
thanks uliwooly. a great help as usual=) LOL. yea. i read that article before. Don't really trust it though. Hope that gingerbreak for 2.3.3 will be out soon!
I know, I really need to root my Arc but we'll see if someone at XDA find a way around it
