Widget to turn off 3G
There are widgets on the 1st home screen to turn off wifi, adjust the volume and brightness, and I added one for GPS.
I want one for 3G radio as well in the same style.
Just wondering if there is anyway to get it in the same style?
KrazyD
Contributor
Hello, there should be a widget called "Data Traffic" which turns on/off your mobile internet.
3 REPLIES 3
KrazyD
Contributor
Uliwooly
Thanks, the widget is exactly what I am looking for. It would be nice if its style was consistent with the other widgets. Perhaps SE could look into that in next fix. It would be an easy fix and it adds to the aesthetic of an already beautiful device.
