Why my xperia X8 charger doesn't work?
My x8 is new. My charger works well in the 1st day. Then I gave charge of my mobile by my pc using the USB cable. After that, when I try to give charge directly using mobile charger it didn't work and doesnt show orange light in the top of the mobile. I tried it with different multi-plug but got same result. I connected it 1 hour with the plug but nothing happen. so I'm now using my pc to give charge of my mobile. but it takes long time. plz help me Slightly_frowning_Face
Uliwooly
Had  you tried a different wall charger?
3 REPLIES 3
Uliwooly
Thanks....new wall carger works great Slightly_smiling_Face
Uliwooly
I'm glad its working, make sure you backup your phone often, just in case it stops working and you need to repair it with Update Service
