anytime even on the startup, the phone is not shaking at anytime, someone can help me?
Here you go, the list of contacts, http://www.sonyericsson.com/cws/corporate/common/contact/phonelist
Hi, do a test using the Service Menu.
Launch Phone Dialler, key in *#*#7378423#*#*, select Service tests>Vibrator, does it vibrate?
If it does, probably a software issue which can be fixed by Factory Data Reset or Software Repair.
Let's just hope it is not a hardware problem.
Keep us updated.
Gwhispererz,
tank you for your help but still no vibration after the service test, what else i can do?
'Still no vibration after the service test' = ? , it's just a test to see if the hardware is working.
Any vibration during the test?
no vibration at all....
Hate to tell you this .... hardware issue! Your only choice is to send it to your local SE Service Centre for repair (warranty?).
I guess i have no more warranty. Where are the SE Service centre nearby Montreal, Canada?
