Problems Updating Xperia Play
Hello All,
I'm trying to update my Xperia Play but I keep running into the same issue.
I run the Sony Ericcsson PC Companion, and click update phone, and all seems to be going well until I get to Step 2. After checking for an update my phone shuts down automatically. Then step 2 says to unplug the phone, turn it off, then plug it back in while holding the Back button. I do all that but nothing happens.
Help would be much appreciated
Jake-SonyXperia
Champion
I suggest trying to perform the update with the Update Service instead. Please use the link below to download this software.
http://www.sonyericsson.com/cws/support/mobilephones/downloads/subject/updateservice/satio?cc=au&lc=...
1 REPLY 1
Jake-SonyXperia
Champion
