guys i've just bought a new xperia x10mini pro a very lovely phone but i'm unable to locate the repeat option in the music player, neither am i able to download a good one from the andriod market... same was the problem with the camera which doesnt have a digital zoom while clicking photos.. pls help somebody... my work depends on my cell phone camera... pls help, i'll be grateful...
I know that Winamp is free, check if you can download that one.
Unfortunately there's no zoom in standard camera application, but maybe you could try Vignette which is available as a demo version for free. I think that application has zoom.
Hi, there is no repeat option on the standard Sony Ericsson music player, howcome you can't download a good one from the Android market?
i cant download from android market as they say incompatible with your phone.. kindly suggest me some music players that i can download from android market which are free and wont harm my phone... thank you...
thank you soooooooo much... u've really sorted out my problem... well i would just like to ask you that is se likely to upgrade its system for the current xperia x10minipro or do we have to depend on these applications till v have sold this phone???
hi... while i was just browsing thru the android market i found something which is very interesting and useful to me a homeopathic materia medica, but unfortunately the only free application which was apparently appreciated by all who downloaded it isnt compatible with my sony ericsson xperia x10 mini pro, can you pls help me with one which suits my phone... i've a memory of 4gb so can easily support but need 1 which is compatible with the phone.... thanks in advance as i am sure u'll definitely be able to find a solution to my problem...:smileyhappy: also wud like you to tell me how to use the astro file manager which i downloaded inorder to find the repeat option for songs but alas cudnt at last.. same with winamp
hi.. i got the repeat song option from the winamp music player that you had suggested me, can you pls help me with a homeopathic software that will be compatible with my mini pro.. a free software which will make my work easy...
