OTA update not working
Hi
I am trying to do the update using wifi connection (since pc companion using mtp mode does not work since the last update) and I get a Coudl not connect to network error!
So I cannot update!
Any other pp works fine on wifi and 3g so it cannot be a connectivityproblem.
I am based in the UK
SE Support can you please take a look at this?
Thanks and best regards
Dr_Chris
Champion
http://www.sonyericsson.com/cws/support/softwaredownloads/xperiaarc?cc=gb&lc=en Have you tried updating by using the SE update service via a USB connection to a PC?
6 REPLIES 6
Dr_Chris
Champion
Uliwooly
most likely SE it's updating the servers, try Update Service or PC Companion
Hi As I have specified in the initial post I cant do it over USB because since companion upgraded to 2.0 the MTM does not work and the update only works on MTM when connected via usb.
I have tried a a few times in different times of the day!
Hi seems the update service wordks in a different way that the update ap in Pc companion... it at least tries to update the phone
But its still not working... not only that ... the phone does not boot anymore!!
Seems the phone has entered some mode that wont boot properly...
Any ideas?
Uliwooly
Use update service without your SD and SIM cards
Uliwooly
If you don't want to wait for the update you can flash it now         http://talk.sonyericsson.com/message/78563#78563
