Hi , im trying to update my phone using pc companion, it said it should take about 30 mins
4 hrs later it still has not finished its still on the prepare bit
i tried cancelling update about 30 mins ago but that is not working either
can anyone advise me what to do please
let me know if it work (it should) and don't forget to install the Xperia launcher on your X10
http://talk.sonyericsson.com/message/56945#56945
http://www.xperiax10.net/2011/02/27/xperia-arc-home-launcher-now-available-for-x10/
and the Gallery app and music app
http://forum.xda-developers.com/showthread.php?t=826311
Download
Gallery_X10
Music_X10
the gallery app will allow you to pinch zoom on your pictures
try Update Service instead
make sure your firewall its off for few minutes and if it doesn't work still then reboot your computer on safe mode then run Update Service
prob a silly question but thats me !!! is it safe to just disconnect my phone from my pc
i wasnt sure if that would cause ant problems
thanks
if your phone on flashmode?
you can unplug it, if it come to worse you will get an error if you try to turn it on but you can fix it either using Update Service or Flashtool
this is how you use flashtool
sorry no isea what flashmode is
i admit to being a techniphobe :smileyblush:
flashmode is when you turn off your phone -> press and hold the back key while connecting the USB cable
thank you i have rebooted pc switched firewall off
im going to try using the link you posted to update now
thanks
Download
Gallery_X10
Music_X10
