Hi all,
I have a Sony Xperia Play R800i.
Android Version 2.3.3
The phone is not rooted, the only tweak that I have performed is to set the SD card as the default storage for applications.
Last night I tried to take a photo using the default 'camera' application though I noticed that the back camera could only take 'Black and White' images.
The funny thing is that the front camera is working and displaying colour.
I am not certain as to the cause of this, though does anyone know of a way to set the back camera back to colour?
Thank you.
try this
settings -> applications -> manage applications -> all -> camera -> clear everything
reboot your phone and if after that the problem persists, backup everything
this is how
download the Backup & Restore app from one of this links
http://forum.xda-developers.com/showthread.php?t=1193802
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkhttp://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
http://www.mediafire.com/?1n07llajeaoo03y
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
just to play it safe sync your contacts w/ google if you haven't already
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
Update Service
http://dl-www.sonyericsson.com/cws/download/1/110/61/1315209439/Update_Service_Setup-2.11.9.6.exe
Hi uliwooly-wooly,
Thank you.
I cleared the application data of the camera, and this did fix the problem.
I would love to upgrade to Android 2.3.4, though I have read that the update to Australia will be released in October - I think I will wait until then to update this.
I have heard that the update will improve the quality of the camera to a high definition quality so I'm quite keen to see whether these rumours are true.
it is, in fact true, it will improve the camera among other things, the update will be out starting October, but who knows if they'll release it soon after in Australia, if you run out of patience you can always flash
