hi
i hav got my arc just 2days back...
when im trying to save contact after entering data, if there is any notification or a new text message in the notification panel then the contact is not getting saved
this happened several times till now..this is driving me crazy..
also i would like to know if there is any simpler way to select multiple contacts for sending a text message like mark several contacts like in traditional phones rather than clicking add recipient all the time??
please help me out..
thanks
you could try Handcent SMS
https://market.android.com/details?id=com.handcent.nextsms&feature=search_result
it will allow you to send sms/mms to multiple contacts
are you syncing your contacts with Google? is your sync on? auto sync on?
go to settings
accounts & sync
check if auto-sync is selected, and make sure your google account is syncing, tap on it and check if contacts is selected
no m saving contacts manually...
not syncronising
the main prob of saving contacts havenot been resolved yet..
Are you getting any error message when this happens?? or is it just noving your contact?
