Text size
Text size
Please tell me that there is a way to enlarge the text of in-coming messages. My eyesight is failing and i need a  telescope to read them. Thank you
gwhispererz
Champion
I'm afraid that is not possible.
Search Market for alternate messaging apps, maybe the texts are bigger?
Just try them out, you can always uninstall them. Winking_Face
You don't need a telescope, you need glasses. :smileymischief:
4 REPLIES 4
gwhispererz
Champion
Thank you, not the answer i was hoping for, may be i should embrace old age gracefully.
Thanks again for your swift answer
Regards
gwhispererz
Champion
Hey .... with age comes wisdom! Slightly_smiling_Face
I use "Go SMS PRO". That app allows you to use alternate fonts.
