problem saving contacts
hi
i hav got my arc just 2days back...
when im trying to save contact after entering data, if there is any notification or a new text message in the notification panel then the contact is not getting saved
this happened several times till now..this is driving me crazy..
also i would like to know if there is any simpler way to select multiple contacts for sending a text message like mark several contacts like in traditional phones rather than clicking add recipient all the time??
please help me out..
thanks
Uliwooly
you could try Handcent SMS
https://market.android.com/details?id=com.handcent.nextsms&feature=search_result
it will allow you to send sms/mms to multiple contacts
5 REPLIES 5
Uliwooly
are you syncing your contacts with Google? is your sync on? auto sync on?
go to settings
               accounts & sync
                              check if auto-sync is selected, and make sure your google account is syncing, tap on it and check if contacts is selected
Uliwooly
no m saving contacts manually...
not syncronising
the main prob of saving contacts havenot been resolved yet.. Neutral_Face
Are you getting any error message when this happens?? or is it just noving your contact?
