I dont seem to be notified whenever i recieve an sms. The phone is only a day old. I get a tone and vibration when recieving a call but not when i get an sms. This is really bugging me and would be very greatful for a sloution.
Thank you.
open your messaging app -> press MENU -> settings -> Notification vibration
Thank you. I feel so stupid because i turned it off. Thank you tho
no problem, don't forget to check the latest Arc Update
