Hi guys, I have a problem, the sound my x10's media is so low-pitched.. however, the sound of ringtones is very good... knowing that, I did augment the sound of the media to its maximum... is there anything I can do to solve this prob?
go to
settings -> applications -> manage applications -> all -> music -> clear everything
also install this Quick Settings app
https://market.android.com/details?id=com.bwx.bequick&feature=search_result
and then go to the Volume Control
go to
The app won't increase the volume (assuming that is what the original poster wanted) but it is a fine app...
What I mean is that the app won't enable one to increase the maximum volume, but it provides a convenient way of adhering various phone settings from one place. It is free, too...
thanks man... it's better now
No problem
