Market application problem
I repaired my x10 mini pro (android 2.1) because i was having a problem with the software.Now i have a market application that gives a download paused error all the time.I am unable to download anything. It(market application) is also not showing up in application->manage applications.What should i do???
gwhispererz
Champion
Strange ....
How about doing another Factory data reset, then try to access Market prior to any data restoration?
9 REPLIES 9
gwhispererz
Champion
Hi, perform Factory Data Reset.
Settings>Privacy>Factory data reset. This will erased your phone memory completely (SD Card not affected), make sure you backup. Good luck. Slightly_smiling_Face
I tried factory data reset but the problem is still there................................
gwhispererz
Champion
Have you tried both Wi-Fi and Data network?
I have only tried the data network because i dont have a wifi network these days...........but previously both networks work fine.......the problem starts when i was downloading an application that was around 16mb in size and my phone ran out of memory..........After that i repaired my phone software,did factory data reset 2 times but still nothing.
gwhispererz
Champion
Did you restore data (settings, apps, etc...) after factory reset and software repair?
Yes(everything except apps and messages)
gwhispererz
Champion
Strange ....
Oooooooooooooooooh GREAT!!!!!!..............That worked like a charm.......................thankyou so much
gwhispererz
Champion
Welcome. Glad that phone is behaving again! Winking_Face
