images do not appear in gallery
may i know y my gallery does not show all my images after i took a new photo and open my arc after shut down?
try all our suggestions
15 REPLIES 15
go to settings -> applications -> manage applications -> all -> gallery -> clear everything then reboot your phone
I believe it may take a few moments just after boot up for the phone to access the files on the memory card.
The phone needs to refresh the list of files in the SD card.
you can always backup everything and repair your phone with Update Service
Backup & Restore app
Use this links to download the apk
http://forum.xda-developers.com/showthread.php?t=1193802
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apk
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
http://www.mediafire.com/?1n07llajeaoo03y
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
just to play it safe sync your contacts w/ google if you haven't already
open your phonebook
press MENU button -> tap on Send Contacts -> select all -> send it to your email
on your computer
-> download the file -> go to your gmail -> click on contacts -> click on more actions -> on the drop down menu click on "import" -> choose the file -> and click import
Apps
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
market my library.JPGmarket my library 02.JPGmarket my library 03.JPGmarket my library 04.JPG
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
did you noticed that the gallery load slower with 2.3.4 than 2.3.3 ?
Now that you mention it, I think it does.:smileysad:
and the same horrendous compression rate Slightly_frowning_Face (camera) hasn't been fixed
i think is my memory card problem, cannot read it (coz i wan to send all my contacts to my gmail which i backup last time in sd card and juz now the phone showed me cannot read sd card), what shud i do for this problem?
and when i go to gallery to see my images the phone showed me "memory card unmounted or not presented"....
try this go to settings -> applications -> manage applications -> all -> gallery -> clear everything
then do this
turn off your phone take the SD card out -> press and hold the power button (w/o the battery) for couple seconds put everything back and turn on your phone, check if it can now read your SD card
Yes. I noticed that. I am actually using the Camera Zoom FX app as my default camera app. It allow you some level of control over the compression ratio.
