I've looked on my phone everywhere, I've looked all over the fourms... I used the companion hoping i could find something. But I can not figure out how to connect to my computer using MTP mode. Can someone please help me?
the verizon version of the Xperia Play lacks of Sony Ericsson features such as the settings -> sony ericsson etc
try this
connect your phone to your computer then wait until you see its recognized by your computer -> drag down the notification bar -> check if you see a connectivity option
Just connect USB saddly.. i've been dealing with this all night.
it doesn't seem that the CDMA version has that other option
Is what i'm trying to get past. Connecting with USB gives me that result.
if its to update your phone try
Update Service
http://dl-www.sonyericsson.com/cws/download/1/110/61/1315209439/Update_Service_Setup-2.11.9.6.exe
Don't forget to backup your phone
Backup & Restore
Use one of this links to download the Backup & Restore app
http://forum.xda-developers.com/showthread.php?t=1193802
or
http://www.elita-clan.com/downloads/backup_and_restore_v010935.apkhttp://www.elita-clan.com/downloads/backup_and_restore_v010935.apkor
http://www.mediafire.com/?1n07llajeaoo03y
How to install it
You need to
go to settings -> applications -> check unknown sources
download IO File Manager
https://market.android.com/details?id=org.openintents.filemanager&feature=search_result
download the backup & restore app, transfer it to your SD card, use OI file manager to find it -> tap on it -> install it
Contacts
just to play it safe sync your contacts w/ google if you haven't already
SMS/MMS
if you don't want to use the backup & restore app then
Install "backup SMS" to back up your SMS and MMS to your Gmail
https://market.android.com/details?id=com.zegoggles.smssync&feature=search_result
or your SMS use
"backup & restore SMS"
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
or for your MMS use "Save MMS"
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
Call Logs
And for call logs this is great
https://market.android.com/details?id=com.yang.android.ansta
I guess I can't use the sony ericsson to update. Thanks for the help tho.
try this
settings -> about phone -> software update
