Help!!! My Xperia x10 mini pro cable failed during the update..
While the update is installing already, the cable got moved accidentally; therefore
disconnecting the phone. Right now, my phone won't even turn on!
It only shows an image of a phone with an exclamation point.
Please somebody help me. I need my phone...............
:smileycry::smileycry::smileycry:
you can try to repair it using either (you should try update service)
PC Companion use this link
or Update Service
http://dl-www.sonyericsson.com/cws/download/1/110/61/1315209439/Update_Service_Setup-2.11.9.6.exe
to repair your phone, know that you will lose your apps, contacts, etc
or Update Service
Hi, don't worry .... follow the steps in the link provided, http://www.sonyericsson.com/cws/support/mobilephones/troubleshooting/subject/upgradeinterruptedbefor....
Keep us updated.
My PC companion says while preparing computer for update:
"Your IP Address is not allowed to update/Repair brown phone.
Please connect to the SMEC network to update your phone"
the other option that will work for sure is
using FlashTool
how..?? can you tell me more about that process using flashtool?
get the Flashtool From here
http://forum.xda-developers.com/showthread.php?t=920746
Install it and you will see 5 folders
This is an step by step guide
5.
a. Unplug your USB cable from the PCb. Power off your phone and plug the USB into the phone
c. Press back button and keep your finger on button
d. Plug USB cable into your PC whilst holding down the back button on your phone
e. A green LED will appear
f. The process will automatically detect your phone and start flashing
g. When "Found at USB/........" appear on flash tool you may release"back button", sit down, relaxand wait.
Hope this is helpful to you
6. IF the "Start Flashing" message appear everything`s ok if not...repeat. Sitdown and relax (again )
7. When last message appear unplug/plug USB cable
Regards,
Ricardo Rendeiro
you can follow the steps on this videos
Don't panic YET .... Download SE Update Service from the link provided by Uli, use that to do a Software Repair, that should fix the problem.
When I'm on the part that prompts me to plug the phone while pressing the back key, it's not getting detected.
