From today the Gallery application doen't work anymore!
When I start it an error message come about process com.sonyericsson.gallery (unexpected interruption).
I tried also to restart the phone.
How to fix it?
Android version 2.3.3.
P.S. The widget on my phone desktop works but when i want to see a pic the same error occurred.
Hi Dynax303, try going to manage application to clear data and cache for this app. Restart phone and try again.
Nothing.
"Gallery" application do not have cache. I deleted data, restart the phone, but the problem is the same
Maybe the app is another or use a kind of service?
There is a way to see a detailed log?
Not sure whether this will work. Try removing SD Card, re-inserting it and access gallery again.
Be sure to power off phone prior to removing SD Card.
you need to backup everything and then repair it with Update Service to fix this issue
to backup everything on the Arc install Backup & Restore App
if you don't want to use the backup & restore app then
or your SMS use
backup & restore SMS
https://market.android.com/details?id=com.riteshsahu.SMSBackupRestore&feature=search_result
and for your MMS use Save MMS
https://market.android.com/details?id=com.schwimmer.android.mmsextract&feature=search_result
just to play it safe sync your contacts w/ google if you haven't already
one last thing
Don't worry so much about backing up your apps
on your computer go to
market.android.com -> log in -> click on My Library -> and send all your apps to your phone
A Software repair is always the LAST option if all fails. At least you tried all possible ways to rectify the issue.
I don't like to backup and restore, there is always a problem on restore (my experience on X10).
Maybe there is another solution to find. Where are the cache files of each picture? I will try to delete these files...
Ok, I have found the solution:
SHOOT A PHOTO!!!
Now it works!!?
