From today the Gallery application doen't work anymore!
When I start it an error message come about process com.sonyericsson.gallery (unexpected interruption).
I tried also to restart the phone.
How to fix it?
Android version 2.3.3.
P.S. The widget on my phone desktop works but when i want to see a pic the same error occurred.
I suggested another alternative
Glad to hear that! See what I mean .... Troubleshoot problem first, a software repair if really NO CHOICE.
I found an incompatibility of Gallery with images generated with SDTools app.
This tool save picture of test results of SD read and write speed. The image file seem to be PNG and often are not visible in Gallery...
Gallery does not support PNG? The presence of png may generate bugs using Gallery app?
Double check if its not the SD card, try to play music and look for any bugs, also check if you have any problems accessing your sd card with a file manager like: OI file manager
I don't think that is an SD card problem. I use everyday audio player without problems
Yesterday, during an Angry Birds Rio session, the phone restarted... maybe that it has corrupted some preview files on gallery?
This restart is not good but the same thing happened on my previous X10...
During game session I used the audio player as ever.
