How do i get back my contacts button, i do not know where it disappeared all of a sudden
When i press the menu button i get only 3 options, Arrange Widget, Change Wallpaper, Arrange Icons.
In the app drawer i am unable to find Contacts App.
do you have 1.6 or 2.1?
here is the user manual
http://www.sonyericsson.com/cws/download/1/816/411/1277381669/U20i__UG_EN_GB_1238-6650_2.pdf
Follow the instructions below,
I have a x10 mini running 2.1. FYKI JAKE I know to arrange icons, here I need to add an icon/shortcut
If this is the case, and you believe that you are unable to find the contacts icon which should be located either on one of the four corners or within the application drawer, a Factory Data Reset will need to be performed. Follow the directions below,
Menu > Settings > Privacy > Factory Data Reset (note: this will remove all data from the handsets memory but will not touch a SIM card or memory stick.)
That will definately work
Come on do not give me a dumb solution. There has got to be a way to add a shortcut, I believe we had this option on 1.6. Currently started using another home screen app so have found a temporary solution
I am simply providing an answer to the query based on the information you have provided throughout this thread, you advised that you are unable to find the contacts icon which looks like a red phone on a white folder, there are two places this can be located on one of the four corners or the second within the applications drawer.
Here is a note directly from the X10 Mini user guide relating to shortcuts to applications
I appreciate the help that u have provided me, don't u think this is a bug that needs a fix??? and also please ask SE developers when they are going to update android versions for x10 mini/pro and x8, there are many people waiting for a long long time for it.
just install the Xperia Arc's launcher
