When i first got my new phone it was fine and charged no problem. Last week i used the update system and
updated my phone for the first time. Since then i am having problems getting it to charge and holding the charge. When plugged into
the elextric socket the normal icon is missing. I have tried switching off and on again but no joy. Try plugging it in with the usb to
my computer and still no charging icon. Tried switching off and it shows the large charging icon in middle of screen. Switch it on and
still no sign that it is acrually charging then a few mins later it bleeps and giives me the choice to download updates etc then about
ten mins later it bleeps again and gives me the choices to download, update and charge. This all seems to have happened after the update and am not sure what is causing it. I am at a loss how to solve this one. The barrery suddenly loses the charge and it takes ages to get it to start
charging whichever method i use. Any ideas what the problem might be ? Any help would be gratefully recieved.
Anytime
