Apps Icons start floating
On and of the icons on the screen (Xperia Arc) start floating around in small (half cm cirkles).
Is this something known as bug, virus, or....?
KrazyD
Contributor
Hello, the icons start floating when you long press one of them, this just means that you can drag them around and change the order of which the icons are presented.
I think it's long press if not it will be when you go to the icon sorting bit.
2 REPLIES 2
KrazyD
Contributor
Txs! It seems to be correct answer even if I dont understand (old man with only a couple of days Arc expeience) the trigger. I cant reproduce the floating - suddenly it starts ;-). But I tested to move icons and it works. I think I need to consult the user guide awailable some where on the net. Many thanks.
