Dear people,
I am facing a serious problem with Sony Xperia M2 with volume. The volume is very low from speaker. Kindly suggest any solution pl
I' m facing the same problem, only i do get a small volume from left channel... The picture quality is zero too. This all after lollipop update...
I too have noticed the volume of the M2 is kinda low.
I don't know if this is because of Lollipop update, I just hadn't paid much attention to it.
I don't know why SONY hasn't come up with any fixes, I am very disappointed for sure.
I have an Xperia M2 and ever since the upgrade to lollipop I have been experiencing sound issues. The volume is very low, and sometimes it doesn't even make the notification sounds. Yes i have tried rebooting, and in safe mode changing the NU player settings, even restored factory settings and nothing works.
I don't want to uninstall the update, I am very happy with all other aspects of lollipop. Is there going to be a fix for this soon, or are we going to have to wait for Marshmallow?
Thanks
Hello.
I have the same problems with the sound .
Whether it is due Lollipop I do not know .
If I record a message and play it back , no sound comes from the speaker , audio only as by telephone without using the loudspeaker.
I hope this will be fixed along with other problems with GPS and camera .
Does not work for me! After upgrading to lollipop, the sound is to low! The safe mode doens't work for me! I need a solution! I hardly hear the phone when I receive calls or sms! It's start to be desperate! Please do something fast!
Hello, I have Sony Xperia M2 Dual, my speaker stopped working but my volume worked without using speaker..
I contacted Sony any I performed everything they suggested with no change..
I had to send to be repaired, they replaced the speaker it now works but its a little scratchy therefore is now is be sent back, hopefully this time it's good...
Thanks
