Sir, today at noon the phone switched off and not started 2hrs after shut down, but after then it is restarting and shutting down automatically.
please help
it's most likely from the battery.It can happen to everyone. You just need to get a new battery.Either buy it and put it on yourself or give your phone to a repairman.Hope it helps.Good luck!
